COBlu77
3k bucks doesn't look like a bad deal?
factory ford will work just fine with a stroker. meter that is cal'd correctly and you will have no issues.
i've run 36 and 42 lb injectors that were spot on for driveability with pro-m, pmas and even the dreaded c&l meter. right now i'm running 60lb injectors with an old pro-m universal meter (360 deg sampling). with no tuning i had a hot start problem (rich) had to floor it to start it. corrected via sct chip tune, i have the software so its a non issue.
if somebody has 3k to spend go for it. if your against factory ford, there are different cheaper options like, megasquirt, aem, accel, etc... some will not be plug in play and require tuning.
i like to preach the factory ford stuff because it is basically plug and play except for running your fuel pump and there hardly anything to that also.
mass flo's setup from the pictures seem to be adapted from ford also.
Ford ECU's are programmed specifically to match the application for which they were intended (air flow, timing, fuel) and do not re-program themselves or "plug-n-play" with new volume (bigger engines) , air flow (MAF's and throttle bodies), timing (cams), fuel (bigger injectors). Throwing parts together Ford or aftermarket cannot be covered up with a reprogrammed MAF that's trying to fool the ECU. Even if you source Ford OEM parts (90 mm Lightning MAF, 30 lb Injectors, and Cobra 65mm throttle body) they won't play together on any size engine without the proper programming. All these parts OEM or aftermarket don't come cheap either.
Ford spent a lot of time and money developing the programming and parts that will work together in a specific vehicle to deliver reliability, driveability in a variety of conditions, and still pass emmissions standards. When you just start changing the variables something has to give. I've got to assume that Mass-Flow's system is engineered and programmed to have it's components work together correctly with your engine and cam, so you don't have to experiment with expensive parts.
