thank you so much dusty, i really appreciate it, i'd love to run your arms but with the economy the way it is i just really can't swing it, currently im running an older 3.5" duff lift that was on the truck when i got it, and a 2 inch body, i figured i'd start with the WH arms and do coils and some other things to the suspension later, i plan on running 35's and staying with 3.5 inches to keep it low slung, as i still drive it daily, and i plan on running some fairly serious trails out here in colorado, and thank you for the advice on the heims and jonny joints, i wasn't sure how often that point of the arm was going to be loaded, i only came to the conclusion of the heims not being good on the street because i know in other applications they wouldn't last on a daily driver, say on an independent suspension, or trac bars and things of the sort, i wasn't totally sure about the jonny joints, and if u don't mind me asking, i've seen the pics of mark's truck on your website and the 78-79 d44 you guys swapped in, and i like the way you had moved the coil buckets out, but what is your personal opinion of just adapting the lower coil cups to sit to the inside edge of the top of the radius arm to make up for the coil mounting points different widths with out moving the radius arms in, something similar to how the user "broncomitch" did on here, i originally wanted to use a 76-77 f-150 d44 so i could cut the c's off an relocate them but could not locate one for a reasonable price, i found my 78-79 d44 for 75 dollars and couldn't pass it up. thank you
