Bundy
- Jan 10, 2009
- 2,045
I am using a harbor freight drill press with a 2 5/8" hole saw bit and i was able to get drill only one hole before i ran into problems.
I tried to have the dash as level as possible, but due to the shape i was only able to get close to level. both of my chucks seperated from their shafts from the bit catching in the metal. Because the chuck shaft has a beveled end, can just drive it back into the chuck with a hammer or are they broken?
What could make the cutting easier, cutting oil? i even changed the belt to the lowest cutting speed like i read and still had problems... i wasn't trying to drill too quickly or anything. maybe i screwed up the bit on the first hole from it being too uneven??:?
any ideas would be immensly appreciated- thanks!
