stoker
- Aug 28, 2011
- 127
I’m running a 351W coupled to a 4-speed top-loader. Over the winter months I pulled the engine and installed a new rear main seal and new LUK clutch. I’ve only put a couple of hundred miles on it so far this summer. The new clutch was engaging at the bottom of the pedal travel (near the floor) but performing fine. Yesterday, on my way home, I felt the pedal “give” slightly and the clutch would not fully disengage with the pedal hard to the floor. I also had increased free play at the top of pedal travel. I figured it was a linkage issue but could find nothing amiss. I adjusted the pushrod to restore the correct free play in the pedal and everything seemed fine at first but soon went back to not fully disengaging after a few shifts. I can’t figure this one out but it looks like I’ll be pulling the engine again to check the clutch. I’m leaning towards a faulty clutch……..
Anybody have similar issues in the past?
Incidentally, the new rear main seal (1-piece, Fel-Pro 2921) still seems to drip oil but I can’t see this causeing the clutch issue.
