Header Bolts & Gaskets
bostonbronconut
Question Asker
Wayland, MA
I've mentioned in a previous that I am getting an odd sound from the engine and all signs are showing that it is the exhaust. I've taken a look at the headers and I noticed that the far two bolts on the driverside headers do not match the rest of the bolts (see photos). It is my hypothesis that the previous owner just threw these on, which is causing a bad seal and the weird sound.
I haven't inspected the gasket yet but could something as simple as a bolt cause a seal issue? What type of bolts do you recommend I replacement with?
Lastly, does it make sense just to replace the gasket at the same time?
Thank you for your help!
spap
Did you tighten them or see if they were loose the bolt to the Allen head bolt will not make a difference probably used to get better access.
Start it when cold and put your hand by where you think the leak is. Can you feel air coming out ? It will get very hot fast. So you have to be quick. If you feel air, the gasket is bad. The noise will be consistent with the engine revs if it is leaking
73azbronco
Those are stainless and probably not the best thing to use for header bolts. Never seen allen screws used there, ever.
blubuckaroo
Grease Monkey
Ridgefield WA
If the gasket has leaked, it's toast. The leaking exhaust burns out the sealing material.
I have never gone overboard on header bolts or gaskets. I use the plain steel reduced head bolts and plain white gaskets that come with Hooker Headers. You can buy them at Summit.
The problem with using a bolt, with some sort of external locking device, is that it makes retorquing more difficult.
Getting the bolt tight enough in the first place is important. Then a couple retorques after several heat cycles. I do use Nord Lock washers under the bolts. Never a leak or loose bolt, and I can easily check them If I like.
https://www.summitracing.com/parts/hok-10984hkr/overview/
https://www.summitracing.com/parts/hok-10820hkr/overview/make/ford
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Nailed it, Spap. I put my hand toward the firewall-side of the header and I could feel air escaping at the same pulse of the engine. I've tightened the bolts before (without over-tightening them) and it clearly hasn't done the job.
I'll order new gaskets and bolts to be safe. I really wanted to work on it this weekend but I can't find any that fits the 302 that are in stock.
Thanks for the help!
spap
Hey 73 what’s the reason not to use stainless
They expand and contract differently ?
chuckji
SE Michigan
The different bolts were probably due to access, as someone else mentioned. In your pictures you can see it would be impossible to get a socket on those if they were hex head bolts.
I'm using and have heard good things about Remflex gaskets.
You can get them from Duff's or Summit.
75MIKE
NE Washington
I have a mix of 3/8 head header bolts and Allens for the access. Along with internal toothed lock washers.
75MIKE
NE Washington
I disagree, I have used stainless header bolts many times and they work fine. Summit sells them:
https://www.summitracing.com/parts/arp-400-1102/overview/
I don't know about the SS head bolts, but I have used them on the flanges with bad results. I had used them on the initial flange install and a year later needed to replace a gasket. I ended up breaking the bolts and nuts as they had seized together like they were welded. I don't know from the heat or what, but I went back with grade 5 and haven't had a problem breaking those loose after a few years.
Bajabrewer
I have a friend that couldn't fix a header leak so he asked me to look at it. After pulling the bolts from one side I noticed 2 bolts were a 1/4 inch longer & were bottoming out not allowing the gasket to crush a little. A new set of bolts fixed the issue & I got a case of beer out of the deal. I like these wedge lock bolts over the stage 8's just make sure you get the right size.
https://shop.broncograveyard.com/Proform-Wedge-Locking-Header-Bolts-3_4/productinfo/10040/
Jfryjfry
I’ve had bad luck with header gaskets. I ordered a set of percy’s Performance gaskets and have my fingers crossed. When I get the motor in and fired up I’ll know!
nickgp
I’ve got a set of Percy’s on a 302 and a set of Mr Gasket branded gaskets similar to the Percy’s. They both seal well, using Stage 8 locking hardware.
El Kabong
Driving stuff Henry built
Another allen guy here. After having troubles getting a socket to fit on header bolts due to the shape of the primary tubes leaving the flange, I have used allens as header bolts for years. The narrow hex shaft on the allen sockets fits in there much easier than regular sockets on hex bolts, or even the small head header bolts. But as mentioned above, I never use stainless there due to concerns over dissimilar metals causing grief.
Rusty_S85
Those were probably used for access, personally I would remove them one by one and replace with actual header bolts they have a smaller head that will allow you to actually get a wrench on them.
On the use of stainless fastners you can use them you just have to remember to coat the threads with antiseize which will prevent fastner galling and corrision from dissimilar metals.
I personally opted for black oxide ARP header fasnters with a 3/8" head for my 302 as I haven't decided what route to go for ceramic coating for my headers. Leaning towards black unless I can find a bare stainless ceramic coat that can be done for a decent price.
But outside of that Ive always used polished stainless steel bolts for holding my valve covers down as I think they look nice against Ford Corporate blue valve covers. Just a little antiseize on the threads before installation and you should be fine.
And if you have aluminum heads you really should use antiseize anyways as it helps protect the aluminum from galling in of itself.
Rusty_S85
Have you ever used the following header gasket?
https://www.summitracing.com/parts/fel-1467
This is the one I have for my 306 build Ive not had any problems out of them at work when swapping out blown out header gaskets of other brands.
The other thing is you have to make sure you have your header bolts as tight as you can get them to prevent blow out as well. I like to start the first and last bolt to hold the header, drop the header gasket in start the other bolts then I start in the middle and work my way outwards and I go over each 3/8" header bolt with a combination wrench using the closed end getting the bolts as tight as they will possibly go.
Now we did have one at work that wouldn't seal, but that ford 351W engine had some Chinese heads on there and the headers the guy bought was Chinese made as well to save money and nothing fit right. In those rare cases you only have a copper header gasket to try and stop a leak at the head.
Braifab
Fort Smith, Arkansas
Bostonbronconut, I work at Schoenfeld Headers and we have header bolts that have a 5/16", 6 point head on them. They are perfect for areas where it is tight to get either a wrench or socket on them. I use a Mac 6 point box wrench that is slightly longer than the standard length wrench and a Mac 6 point swivel socket (1/4" drive) to run the bolts in with. You should always replace the gasket and be sure to tighten the bolts from the center moving out to the ends. Standard Ford Windsor gaskets are also in stock. Give us a call and ask for Mark. (479-474-7529)
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Thank you for all of the information and advice!
I bought the Percy 66014 Seal-4-Good Flange Gaskets and ARP Header Bolts with 12-Point Heads.
I installed the gasket and bolts yesterday and it has fixed the exhaust leak I was getting from driver-side, firewall header/manifold. It sounds SO much better! I'm going to retorque the bolts after my next drive.
