Choke stove, or choke heater, lines. On the stock Motorcraft carbs this line sucked hot air from the exhaust manifold to help heat the automatic choke. The line went from a connection at the top of the carb to supply filtered air, down to the exhaust mainfold, then back up to a connection at the choke assy. There was a hole behind the choke assy to supply vacuum to suck the air through the tubing. The line going back to the choke assy usually had a fiberglass insulator on it.
You can duplicate that by just using a length of tubing to run from the carb fresh air connection, make a couple wraps around one of the header tubes, then back up to the choke.
The Edelbrock Performer doesn't have this provision.
