Wild Horses Shorty headers install question?
needabronco
Prescott/Farmington
I'm installing a pair of WH shorty headers and I'm very impressed with everything so far. I'm a bit stumped on where to mount the stock Bronco dipstick tube, there doesn't appear to be room. For those of you with Shorty headers and a stock Bronco oil pan, what did you do for your dipstick tube? If you have pictures feel free to post them.
Thanks.
needabronco
needabronco
Prescott/Farmington
Dack, my exhaust is the original stock exhaust down to the original Fomoco muffler! The pipes are good, but the muffler has seen better days.
Justino, did you cut off the mounting flange? That's what I was thinking of doing, but I wasn't sure it would stay put?
burntfish
ouray, co
I thought you already had headers. Still collecting parts for my explorer swap and need headers. Good luck with the install.
nickgp
When I was running the stock pan I used the stock dipstick tube on the passenger side. Welded a stud to a head bolt, installed it, bent a bracket up and welded it to the dipstick. Worked great until I decided to use a Milodon 8qt pan. It has the dipstick bung on the drivers side. No way to get the stock dipstick or even a braided steel flex dipstick tube thru the header. Plugged the driverside bung and welded one into the passenger side of the pan.
Bituman
Phoenix Mtn Preserve
Mine just slid in between two of the tubes. Stock location on the passenger side.
Yes, same here. I used a flex tube for a while, and picture shows what it looked like. Can't remember if I ever tried with the stock tube. Couple years ago I switched to the Milodon plan like Nick, and had to fab up something for drivers side like he did.
Bob
