Headlight adjusting screw
wrangler
Gallatin,TN
Just broke 2 new ones is there a trick to getting the little tabs to pop out when you pull or push it through the hole? I pry the tabs out a little but when I put it through the hole they flatten back out. When you do this a couple of times the tabs will break off. Thanks
The new ones are breaking? Hmm, are you taking the screws out of the plastic before you push them through the holes?
W
wrangler
Gallatin,TN
Yeah tried taking the screw out it looks like the little metal tabs won't come through enough I was wondering if paint thickness would make a difference
