Headlight Appears fogged. Replace from where?
BrianMetzger
Hello all.
Forgive me, I know this forum pertains to 66-77 Broncos only, and while I have a 94 Bronco, I feel that my question can still be answered in this forum.
Anyways as I've said before, I own a 1994 Ford Bronco (Eddie Bauer 2dr SUV 4WD) that I purchased from a friend two years ago. Just yesterday I noticed that the driver side headlight of my vehicle appears opaque (i believe this is referred to as headlight fogging). The assembly appeared transparent when I first obtained the vehicle, so I know it's not supposed to look like this. I also noticed a small fracture in the housing, which I assume allowed moisture to enter into the light.
Now that I must replace the light, I've decided to do so by purchasing an aftermarket one from an online store. I found two sites that I may potentially purchase from, but the prices between the stores for the product are significantly different, which is why I'm suspicious of them. Can anyone tell me if either of these sites is legitimate? I just don't want to hand my money over to a scammer. Thanks in advance.
http://vehicle-interior-parts.amazo...src=froogle&utm_medium=CSE&utm_source=froogle
and
http://www.go-part.com/9296-ford-bronco-headlight-assembly-left-driver-p-12747.html
Skiddy
just replaced both of mine on my 97 F250, both places have been around awhile and havn't heard anything bad about them. i got mine off of ebay a pain to change out though
broncnaz
I''d say either site would be fine to order from. The top link didnt show there price and the part was out of stock anyhow but I would say $30-40 is the going rate for replacements.
And if yours is indeed cracked and moisture is getting in, that seems to be a great price for a full replacement housing.
However, if you ever run across a fogged housing that's still intact, you can buff them out just like paint and get rid of the fog.
You might even try it while you're deciding on the replacement. I've used several products, from task-specific polishes, to standard paint polish stuff, and have had good (if a bit mixed) results with both.
On the Mustang I did a few months ago, there was still some slight haze left after taking a buffing wheel with some standard polish to it, but the amount of light coming out of them was increased by a huge amount. Very satisfied.
Even had decent luck with a hand-applicator just for headlight lens defogging. It was ok, but I had more fun with the power drill and buffing wheel.
Good luck either way. Let us know which way you go and how it comes out.
