So I just installed headlights and relay harness this morning and everything worked great. Low beams, high beams and switch all worked as it should. This afternoon I had started the engine after making some adjustments with the fuel injection handheld and was letting it warm up to operating temp. I turned the headlights on and was looking at their brightness with the engine running when they switched to hi beams on their own. I went and depressed the hi beam floor switch but they would not go back to low beam. I also turned them off and when I pulled the switch back out the headlights came on in the parking light position and still on high beam only. Does this sound like a light switch problem? I had read that with the higher wattage halogen lights that they would cause switch issues if you ran them without the relays, but as I said I do have the relay harness. I checked all the grounds and everything looks good, just seams like the switch is stuck internally or something? Anybody had issues like this before?
