Headlight Switch Mounting Position???
broncoitis
Don't think that this has ever been asked but I wanna put the intermittent wiper switch in my Bronco. Problem is that it will not fit in the given space as things currently are. I was able to rotate the headlight switch 90 degrees with the side pointing up and able to get the intermittant wiper switch to fit.
Does anybody think that mounting the headlight switch on its side will cause any problems??? I wouldn't think so but maybe it has to remain upright! %)
Thanks for the thougts!
Nope. Pretty sure it doesn't care as long as you can get your fingers on the little button when it's needed, and the wires from the connector aren't under too much strain from the twist.
It's how I'd do it I'm sure. Maybe someone else has more info on that, but I'd say you're good to go.
broncoitis
broncoitis
Thanks Paul,
I didn't think so either. No strain and the little button is still accessable and plenty of length on the wires. Only thing I was wondering about was possibly that little ball on top being able to find its way out of place. Ahh, gonna run it this way till something goes wrong I guess! ;D
Rob
70_Steve
Old Guy
Should be no problem. They stopped using Headlight fluid sometime in the early 50's, so no chance of loosing that.
But the turn signal switch is a different story, as they continued to use blinker fluid well into the 90's.
xcntrk
NOVA
You could always move one of the two switches. My headlight switch is on the p-side of my steering column due to through-the-dash cage interference. Being right handed, I like it there - right next to my hazards.
broncoitis
broncoitis
Whew! Glad I didn't make that mistake! :eek: I never even knew that they had headlight fluid back then but that makes sense. Now the Blinker fluid you totally have me confused with that! :-[
