Headlight switch re-install issue
hammer
Painted my dash and now I`m putting it back together. Got the headlight switch all mounted up but when i push the stem/knob into the front of it nothing catches it. It just keeps sliding in and out. I tried fiddling with the button on the back hoping it would grab onto the stem but to no avail. Did I break something inside it when I initially removed it?
It's possible to break something, but it's unusual. I guess if it's old enough...
But I've had plenty of issues with this over the years that it makes me think you just have to keep fiddling with it.
Perhaps feel the tip to make sure there are no burrs or anything that would hurt, and try it in all three positions (triangle shaped shaft, right?) to see if it matters.
I've had good luck by pushing the button to help too, so keep trying that angle as well.
Good luck.
buildabronco.com
Tekonsha, Mi
Exactly what DirtDonk said. I usually push the button in while jamming the knob in and out real fast. Sounds kinky but it always works. Or hold button down put in knob then let go of button while pulling knob out.
