Headlights go dark when I turn on hi beams
dsmelfi
@EmmaBronc
New York
Hi. I've upgraded my headlights (speaker 8700) and bought the upgraded headlight harness. Checked all the wiring and grounds are all good .. but when I turn the hi beams on, the lights turn off completely. Has anyone run into this? Centech harness was installed about a year ago... Thanks! Any ideas are most welcome!
Slowleak
Georgia
Does the high beam indicator on the dash come on? If not, you may have a bad dimmer switch. Check the green/black wire coming out of the dimmer switch for power when the high beams are on.
Speedrdr
OLD night owl
Paris, MS
Had the same problem with my ‘72, except it was the other way and low beam didn’t work. Was a long two hour drive at night Felt a little sorry for the oncoming traffic. Took the 2nd new dimmer switche to correct problem…and this was with OEM lights.
Randy
dsmelfi
dsmelfi
@EmmaBronc
New York
I also have a classic instruments cluster.. but yes. The indicator light does come on when I hit the switch. I'll check the wire tho
Slowleak
Georgia
Sounds like you are getting power thru the dimmer switch. I would check the high beam relay in the upgraded harness. I had one go out in my harness from Tom’s.
dsmelfi
dsmelfi
@EmmaBronc
New York
It was indeed the relay! Had some rust in there so I cleaned it up with a wire brush and they seem to be working! I'll have to order a new one but hopefully it will hold for a couple days. Thank you for the assist!!
