B&M has tranny coolers listed in BTU/hr. If I want my tranny fluid to run at 180 then what temperature does it come back from the cooler, 140? 150?. Is a 40°F drop realistic?
so, 1 gal/min / 7.481gal/ft3 X 60min/hr X 54 lbs/ft3 X 0.5 Btu/lb°F X 40 = 8,674 btu/hr.
200-140~13,000 BTU/hr
So they have 9,800 Btu/hr up to 14,000 Btu/hr. I am not sure how they rate these because it will depend on the cooling fluid temperature and mass flow? Anyway, I need an exchange with a rated duty of say 14,000 worst case.
The 14,000 Btu/hr is 11" long by 5-3/4" wide. So if I assume crawling in the mountains with a summer temperature of 85°F and an altitude of 10,000 ft then the density of air is 0.052 lbs/ft3. The Cp of air is 0.26 Btu/lb °F. Surface area is .44ft2, assume a velocity of 30 mph or 158,400 fphr, the volumetric flow rate is 69,696 cfh. Mass flow rate is 3,624 lbs/hr. Then the temperature differential would have to be 15°F.
I don't know if this is realistic and I am finding out that the cooler manufacturers do not provide enough information to actually do a educated sizing for the cooler. So, I guess I will go with the largest one I can fit in front of the radiator. %)
