You pick the most convenient header tube to line up under the air-cleaner's "snorkel" and clamp it on using the welded cross-brace as your clamping surface. Usually you'd use one of the front two tubes, but that's up to the individual layout. Different years placed the snorkel in slightly different locations.
Then you just attach the existing heat-riser hose that should be present between the intake snorkel and the stock manifold cover. You're only looking for hot air to rise up through the tube into the intake, so it does not have to be sealed or any fancy mounting procedure followed.
I misspoke before, about them being weld-on items. Forgot the cross-brace was for clamping purposes.
That's for the heat riser to the snorkel though. The kits don't come with a provision for the heat tube that hooks to the choke after all.
Most trucks have lost them, or the owners have removed them while doing different mods, but, since it sounds like you still have yours, you might be able to remove them from your stock manifolds and simply lay them on a header tube and clamp them in place.
Not sure how easy that will be though, as most every one I've ever seen was pretty rusted down at the manifold, and won't simply pull out anymore. If yours are stuck or deteriorated beyond use, the aftermarket "HELP" piece I mentioned before might be your only choice.
