Heater Box rebuild
bronco_daddy
Paso Robles, CA
Hey guys...been a while.
In the process of rebuilding my heater box with a bigger motor wheel and as I was putting it back together I noticed my new foam seal kit was missing a piece. Above and below the heater core is an elongated foam U- piece and I have only one..GRRRRRRRRRRR. What I am needing is a type of foam that is compatible with the heat and contact. Sucks as this is the last piece on this to put back together and the job came out bitchin...
Bob-
stingus
Nashville,
I used foam weatherstrip tape from home depot on my rebuild and It worked fine. I just cut it to the size I needed.
jakestaaa
I am getting ready to dive into my heater box. I have a gasket kit and new core but........ what is this about a bigger motor wheel. Is this something i should consider before i get started. Its flippin cold this winter!
mortimersnerd
Search for the Chevy blower motor and wheel swap. Makes a big difference and the parts are only about $50 new. Would be very cheap w/JY parts.
markperry
I just used The Right stuff spray foam.....just be careful you don't spray too much.....then trim the excess and spray some black paint on it!
