Heater control valve and upper radiator hose
73 bronco 347
I am in the process of putting a fuel injected 5.0 in my 73 bronco. I have a ron davis radiator. I would appreciate any idea on what upper radiator hose to run and what y'all did for your heater control valve and heater hoses. I did try to search it on here but for some reason it won't let me. Thank you
904Bronco
San Martin, CA
5.0 Reverse flow or standard flow water pump? (or what front dress are you using)
Heater Hoses alone or using either Mustang or Explorer heater tubes?
904Bronco
San Martin, CA
So my Buddy with a 351 / Champion Rad / Explorer dress used this lower hose and made the 88-93 Mustang upper hose work for him.
Whether Explorer or Mustang, the water pump exits on the Drivers side.
Now I remember that that the Mustang upper hose fit a little better than this picture shows? ?:?
I am still looking for pictures of my 75 that was Mustang front dress...But it has been 16 years since I owned it. I will keep looking.
On the lower hose with a Mustang front dress it kind of matters on where the PS pump is mounted. If it is high up from a rig that had no AC or down low with an idler pulley (in place for the removed ac compressor) High position/AC delete - shown in the last picture...
On the Mustang heater tubes... One of the discharges is 3/4" and the other is 5/8". I am pretty sure I remember that the larger on is the supply side from the intake. On that fitting I used a the same by-pass hose from the thermostat housing to the water pump, as one side is 3/4 and the other 5/8. You shorten the 5/8" side a little and install your heater control valve in that one. For the other end and the return hoses... Gates makes 5/8" hoses with 90* bends in them of various lengths. You can cut them down and splice them if need be.
73 bronco 347
My upper radiator hose enters the radiator on the drivers side. That's the issue I am having. Some one on here told me a fyi radiator hose but I can not remember exactly
904Bronco
San Martin, CA
If memory serves me... 69 GTO with AC.
I like the stock Bronco upper hose #60710 made by Continental... formerly Goodyear. It is different than the other manufacturers...
I put it on backwards with a splice for upper Explorer dress with Factory Rad position.
73 bronco 347
I will try that thank you
