First post for a long time lurker. I bought a 73 Ranger a month or so ago and have been doing a bunch of work on it. I'm hoping you guys can help with a weird problem.
Not long after I brought it home, my heater core blew up. I bypassed it by connecting the hose from the intake to the water pump. Everything ran well.
I decided to replace the heater core, which, of course, meant rebuilding the heater box, replacing the dash pulls, new seals, etc. Everything went back together correctly and seemed to be working properly.
The problems started when I hooked the new heater core up again. I hooked up the hoses (with the temp valve closed), started it up, then pulled the knob to open the temp valve.
Engine immediately died.
I realized I probably should have filled the hoses and new heater core with coolant before starting the engine, so I did that.
Ever since, the engine will start up from cold and run briefly (2-3 minutes), but will eventually die. It wont idle well.
I have a manual choke on this truck - it doesnt seem to have any effect on how well the engine runs. No matter how much I play with the choke, I can't get the engine to idle/run as it did before this project.
I've tried burping the cooling system. I don't seem to have overheating problems.
I just cant figure out why the cooling system would mess with the idle.
Any ideas? What am I missing here?
