heater Fan going constantly
tk1218
Flower Mound
I have reviewed the wiring diagrams and cant seem to figure out the issue related to my fan running constantly when the ignition key is turned. i have verified the power in and the 2 wires going to the fan.
Is the switch bad?
tk1218
tk1218
Flower Mound
Sorry, 73 bronco.
I have an aftermarket GM based harness on the truck. Fan runs all the time when ignition hot.
not sure i have the wires correct. Right now the orange wire with the round connector is not connected to anything. I checked this wire and it is neutral (no power or ground). Other wires are going from the switch to the fan. The orange wire that has the round wire connector off of it is on the passenger side of the switch.
Please let me know if you need additional information
What was it? Switch, or the hot wire bypassing the switch altogether?
Do you know what brand harness it is?
Cool. Glad you found it so quickly. Thanks for updating with the culprit.
