I could ask my friend to test it, not good or certain I have the right tools or knowledge to test a resistor. Would be easy now to just replace resistor, then everything should be replaced.
Will check with TBP about a resistor or local parts store.
If he doesn't have a chance to test it with an ohm-meter, you can simply hook it up to the new motor just the way it is right now, attach the power and ground wires to the battery and see if it starts up with 2 speeds.
If it does, you're good to go.
Not sure if they are even available new. Haven't seen them, but haven't looked much either. Maybe the Mustang crowd or the LMC type companies have them? They don't fail very often, but if they're available it might not hurt us to have some laying around anyway.
Won't make sense to borrow one off the other boxes I have laying around.
Actually, since they fail so seldom, it might not be such a bad thing after all. Chances are pretty good that most of the ones you find laying around will still work. Rust is likely the biggest issue, but easy to test.
When I had my first Bronco 25 years ago, used to let this dangle in the winter to suck in already heated air from the cab. Also I would block the passenger side cold air duct. Thinking this was better to reheat the air already in the truck. My friend who is a mechanic for Ford over 30 years tells me the you want that air being blown in over the core.
The way you did it, air was still being sucked over the core. It was just taking it from the inside rather than the outside.
The real downside to recirculated air is that it's not as efficient at defrosting the windshield. With an already sorry excuse for a defroster, that could make the difference in deciding whether to block off the fresh air intake or not.
At any rate guess I will be adding a new stock thermostat and a gallon of antifreeze to my list. I think the PO might have a lower 170 thermostat because he keep top off and only drove in summer. Any thoughts? Thanks Again, Slim
Yes, go with at least a 180° version. Some even bump it up to a 195°, but that's usually better with the EFI folks. While it can work with a carb, I think the 180 is a better choice. Double check of course, but that should have been the factory rating.
Good luck.
