I guess the 90 degree hose is the way to go. I suppose that is supposed to go into the heater control valve that I don't have (which controls the fluid flowing through the new aluminum heater core)?
Yes, it's probably the best basic solution.
For the valve, the factory would have had the control valve on the top of the engine, just behind the carburetor area (you really just set it up based on the length of the cable) with the inner hose running up there, and the outer hose running along the side to the water pump fitting.
They got a little cleaner on those later years, probably due to filling the areas up with all sorts of other stuff. The clamp that jckkys mentioned on his '77 would have been a good thing for keeping them tidy and from rubbing on other stuff.
I "slightly" disagree with him on the fact that it wasn't a problem though. Not disagreeing that they actually work fine and live long lives under those conditions, but any time you can stop something rubber from rubbing on something made of steel, that's a good thing. And getting rid of 90 degree bends isn't actually a bad thing either.
So straight out the firewall (stock straight hoses) is good for flow, but can't be done due to clearance issues.
It's gotta' bend at some point of course, but keeping those bends gradual, rather than tight 90's could have an advantage.
Of course, nowadays most of the new cars I've checked out under the hood have all sorts of bends in their heater hoses to keep them up tight against things and out of the way of others. So like he said, it's probably not a problem worth fixing. As long as your cooling system has good flow pressure and sufficient fluid, overall flow is likely sufficient for our heater core size.
The straight hoses were stock, at least in the early years, so I always at least cut and split a section of old hose and strapped it around the one rubbing metal to protect it.
Were 90's stock on your '77 jckkys?
...but during the day without the blower on I don't feel heat trickling down on my feet or anything. I guess if it was all sealed up I might, but I certainly don't right now.
Maybe yours is sealed up well. Or were you referring to the Bronco itself being without a top? Maybe it just dissipates too quickly then for you to feel much at the foot.
Are you "pulling for heat" when you're checking? To get any heated air through the box you need to pull the fan control knob to open the damper door.
I assume you know this, as you say your heater is working well when you need it. But sealing it up isn't going to increase hot air coming out the vent when you're not using it.
Might get better air flow through the system (with the fan off) once you put the hood back on? Not sure how much help the hood surface would be for helping to direct air down the passenger heater intake, but I bet it's at least somewhat helpful.
Not sure who else sells. However, not certain this one connects to the factory defrost ducting, which I bought before I knew about classicbroncos.com.
Just helped with one in another Bronco, and that one does not have a facility for defrost. The owner is really only concerned with defrost though (he thinks anyway!), so hooked the outputs to the defroster ducts instead of using it as a heater.
