JakeAlex
Ok…I need a lesson in heat 101. I have completely rebuilt my box. I tested with a 9 volt and she works. I hooked up to the existing wires, and no dice. tried with the key on...no dice. Next step was to check fuses. I replaced all fuses, but still didn’t work. I decided to order a new heater switch. Just installed it but it still doesn’t work. I have the ground attached to the heater box and it worked with the 9 volt so I assume I should be good. all this being said, I figure Id add some pics so maybe one of you fine gents can get me on track.
few other questions I have...
Can someone tell me if it matters which color wire (in pic) is hooked to which post on the back of the heater (left of my pointer finger in pic of motor)? I know the longer wire hooks to my motor. I’ve tried hooking each wire to each side but I still don’t get a working heater.
This thread mentions "pull for heat" several times. that being said, in the pic of the heater, you'll see I’m pointing at two levers for the directional flaps. when I took the heater out to rebuild, none of the cables where hooked up. according to my dash, I have 3 cables to hook to the heater but I only see the two "levers" that I'm pointing to. I’m sure I know where two of the cables hook to but where does the "pull for heat" cable hook on the heater?
I've read through this post a few times but didn’t remember reading anything about my issues. hopefully I didn’t overlook it if it was mentioned. At this point I feel the wiring is hooked up correctly and I’m mainly in need of knowing where the 3 cables hook up at. This being said, can anyone tell me what else I can look for since my heater still doesn’t work? Thanks in advance to any help you can provide.
Jake
Jake
