Hedman Shorty Hedders
dao1980
Chattanooga
I'm running those headers on my 351w in the F150.
Be sure to check the welds on the inside of the main flange that mounts to the head.
I had to clear out a whole lotta buger-bears and overzealous bead that was closing off the port a little and would have impeded flow out of the exhaust port. Other than that they're a great bargain header if you can do a little mod to get them nestled into a bronco.
The JBA's that I've got on the bronco needed no such extra work, and are very nice for the bronco at a slightly higher price.
I would love to throw down for a set of Wildhorses4x4 shorties, but the fixed starving student budget keeps tweeking the nips. I'll post pics when I'm done.
Sounds great. Let us know how they work out. Judging by what the others have said, looks like you'll be doing at least a bit of modding to get to that happy place.
Probably a good reason to go with the bare ones then, as opposed to cutting up some nicely ceramic coated version.
Can't wait for some pics and reports.
KyleQ
I'm curious as well, 351W with GT40's do NOT like the 74' manifolds...
ENDLIFE
ENDLIFE
One more comparison with headers from Bronco Hut.
images
ENDLIFE
ENDLIFE
@ 70_Steve: I would have dismissed the notion as well, but more than one person told me the same thing about the headers. Besides my exhaust leaks, I have to do something about code 41, and hopefully a leak free exhaust is the first step. If you have any info on solving the code 41 please let me know, because it is killing my soul.
70_Steve
Old Guy
What troubleshooting have you done so far? There's always "stuff" you can try, to help narrow down the problem.
Was that 41 seen just KOEO, just KOER or both?
Pull the plugs and compair between all 4 on the right side, and to the left side. Maybe it really is running lean, or maybe there's just one or two cylinders running lean, possibly indicating a clogged injector or two.
Swap O2 sensors side to side. Does the code follow an O2 sensor?
ENDLIFE
ENDLIFE
I'll try swapping O2 sensors first, but the test was KOEO. We'll see what happens soon, as winter driving with the top on is literally killing me.
67 Halfcab
Here are the pics you requested. If you need any more, let me know.
67 Halfcab
a few more.......
Nice. Clean routing.
But how does that thing steer? ;D
Did you do the mockup and welding Halfcab? Very clean indeed.
Did you buy one of the tubing "kits" or just a bunch of tubing in the sizes and bends you wanted?
KyleQ
Very nice - but what did you have to do to them to get them to clear. It doesn't look like they were modified at all....
67 Halfcab
Didn't modify them at all. My combo is Headman 88408 headers (heavy duty version of 88400's) WH Extreme Motor Mounts, 3" body lift, and had to cut off the extra "ear" on the passenger side of the 4r70w. The driver side routing may interfere with the driveline for my HP44 with 3" suspension lift. Once I order my extended Tom Woods driveshaft I might have to do a little "clearancing" to the tubing so it will clear.
67 Halfcab
When I ordered the headers from Summit I also ordered a 4 or 5 180* bends. I just spent a few days with a chop saw, grinder, angle finder, sharpie, and a mig welder and slowly fit it up. I wanted to do it myself so I could get everything tucked up high and out of the way. It isn't fully welded up yet, just tacked into place. I still have to buy some strait tubing to finish up mounting the muffler and then route it out the back. I also plan on doing some header wrap on the tubing where it wraps around the tranny pan.
KyleQ
Wow - the 88400 headers are cheap too! I've got an oven, so I can coat them myself after whatever I have to do to make them to fit.
The extreme motor mounts lift the engine a bit, so you may have gotten clearance there. I've got 5.5" of lift and a HPD60 - maybe its worth the risk to see if they fit... They will always fit on any 90's Ford truck if they don't clear for some odd reason.
Thanks for the tip-
