73EB
Any ideas to keep the dist from hitting the heater core fitting? can it moved to the themostate housing?
You could possibly change out the fitting for one with a 45* angle. Should be easy to find at any hardware store.
i think when i had it in mine i did a combo of both by putting it a few teeth over and getting a diffrent elbow for the watre deal. here is a link to my gallery i hop you see how i have mine set up
http://classicbroncos.com/photos/sho...6/ppuser/20321
if i remember right i ran one from ground BAttery and one to the key on ignition under the dash. cant say what color wires as i put in a whole new harness since then an dit aint stock to say the lease.
but it should be easy to run new wires if you dont have the stock available to you.
