I 'm curious what type of hemi joint, have you guys used on track bar? I thinking of changing the end that bolts to the frame with a hemi joint and leaving the axle end urethane bushings. My track bar is 7/8 -14 threads and 9/16 bolt. I know hemi transmit vibration so I think if I leave the axle urethane, it will help. My 74 is not a daily driver so not worried to much. I've been looking at Barnes 4wd XM12-14-CR Heat Treated Chromoly 7/8-14x3/4 RH Magnum Series HEIM, I like it because it has 4 inch long threads for good engagement , I'm thinking of using 3/4 High misalignment spacers ss to 9/16 hole.
Thanks Dave
Thanks Dave
