Hellwig Sway Bars/Krawlers Edge - Updated!
KrawlersEdge
Louisville, TN
Available from Krawlers Edge…Hellwig Sway bars for your 66-77 Early Bronco!
We have Hellwig front and rear sway bars available for order with a typical lead time of 6-8 weeks. Hellwig Sway Bars offer the ultimate in "streetability" for your rig with the ability to be off-road in minutes. Manufactured by Hellwig, www.hellwigproducts.com, to be purchased thru Krawlers Edge. The installation kit comes with easy to follow instructions including helpful pictures to follow along the way. Check out pictures below of installation on our customer’s Bronco.
Please call us at (865)297-3478 or email us at info@krawlersedge.com with questions or for additional pricing information! You can also learn more about EVERYTHING we do at http://www.krawlersedge.com!
3"-5.5" Lift Front Sway Bar w/ Disconnect (7868) $735.49
3"-5.5" Lift Front Sway Bar w/out Disconnect (7867) $463.15
3"-5.5" Rear Sway Bar w/out Disconnect (7869) $305.25
0"-2.5" Lift Front Sway Bar w/out Disconnect (7864) $429.04
0"-2.5 Lift Rear Sway Bar w/out Disconnect (7863) $338.00
KrawlersEdge
KrawlersEdge
Louisville, TN
Rear Sway Bar Pics
The rear sway bar in these pics was a prototype. The new one will be a few inches shorter for more clearance on the leaf springs and the top link mount will bolt through the frame, for a tighter, cleaner fit.
Lightnin' Bronc
I have done a couple of upgrades to my 74 bronco over the last 8 years. Some have just been okay and some have been "WOW", I wish I would have done this sooner. I would definitely say the Hellwig sway bars have been one of the best modification I have done to date. This installation went smooth and the quality of parts are shown throughout the kit. I haven't been able to enjoy the power of my 351 Lightning engine, due to the unstable feeling around any corner. I will have to admit my truck is setup up for off-road with a 5.5 long arm suspension kit and 38inch Super Swampers. It is not really setup for the twisty roads. That is why the Hellwig sway bars has definitely transformed my bronco into more of a back road blast. The other great part of this kit is that it is very easy, with the pull of two pins in the front to set the suspension back to the trail ready truck it was before.
KrawlersEdge
KrawlersEdge
Louisville, TN
Wow!
I help Lightnin Bronc install the front and rear sway bars. Great job Hellwig!!!
I have drove" Lightnin Bronc" this bronco before and after the install, what a differences the sway bars made. Without sway bars this bronco was like a slinky, with the Cage 5.5 long arm kit and the 38" tsl's. With the power of this bronco under acceleration it was a hand full, braking was a issue also. Now the bronco is very predictable under acceleration and braking. Just a pleasure to drive on the street now. Then with the pull of two pin's it "Lightnin Bronc" is back to the flexing machine it is.
nvrstuk
PNW
How do those 38"s NOT hit the bar?
There is no way that bar can be on the outside of the strg box and not be hit by the tire...least not with my 37"s on my rig... yes, the axle is centered, yes I run Cage arms to allow full turning radius... yes, my tire on a full right turn touches my strg box.
Just wondering how it can work on the outside.
KrawlersEdge
KrawlersEdge
Louisville, TN
NVRSTUK,
Lightnin'Bronc is running an 1.25" wheel spacer in the front. We checked from lock to lock and it looked like we had somewhere around 1" to 1.5" clearance in sway bar. I feel sure if he removed the spacer it would still clear but in a hard articulation, fully locked it may rub a little. Hellwig really did their homework on the clearance issues. Please let me know if you have any further questions.
KrawlersEdge
KrawlersEdge
Louisville, TN
the front would be perfect for my set up- 3 link w/coilovers- price?
Gravy,
Prices are as follows:
7868- Front sway bar w/ disconnect- $498
7867- Front sway bar w/o discinnect- $345
7869- Rear sway bar w/o disconnect- $260
Please let me know if you have any other questions. Thank you.
lonesouth
Good looking design. I wasn't sure that the body was going to be a good choice to mount the link to, until I realized that was in the unlinked mode and it was just pinned out of the way.
Does this reuse the stock coil retainer bolts or are they replaced with new? Any issues with this putting forces on the retainer/bottom plate that the design(original bronco) did not allow for? Seems like whenever the system is active, there is a leverage force on the coil bottom plate forward on one side and aft on the other.
tim70
SF Bay, CA
What is the body/suspension lift range for the sway bars? The Hellwig site shows a 3-4" lift range only.
ken75ranger
Troy, NY
I have a couple of questions.
Have you tried the front sway bar with a stock pitman arm?
Did you have to remove the front bumper and fish the bolts sown the frame?
KrawlersEdge
KrawlersEdge
Louisville, TN
The Bronco that we tested this on has a 5.5" Cage long arm kit with no problems with the installation or clearance problems. There is a lot of adjustment in the links that connect the sway bar to the axle. So I would confidently say this sway bar kit can accommodate up to a 5.5" lift kit.
KrawlersEdge
KrawlersEdge
Louisville, TN
We "Krawlers Edge" have not tested with a stock pitman arm. I know that Hellwig has been developing the Front and Rear sway bars for about 2 years. I know they have tried many different applications. Examples, different steering boxes, lift kits, and etc., trying to accommodate all the different variations. But to answer your question I don't know 100% for sure. They recommend removing the front bumper but we didn't when we installed the kit. They send a plate that you slip inside of the frame. We were able to do this in the fish mouth opening on the inside part of the frame. The plate is drilled and tapped so there is no reason to have any tools. The only tool you may need is a extendo-magnet to help align the plate to start your bolts.
KrawlersEdge
KrawlersEdge
Louisville, TN
The kit doesn't come with longer bolts. I do see your point on this, but the way I see it is it helps the lower coil cup because it gives it a bigger surface area to rest on, so the coil cup sits level. It is a 3/8" plate that is in between the radius arm and coil cup. As far as the leverage force we would have to ask Hellwig. I do know that Hellwig has been developing and testing this system for about two years. Also, this is what Hellwig does all the time.
Bknaus
Visalia, CA
Hey everyone, I figured I'd make an account to help field some questions on the new Hellwig sway bars. Also, we have a 68 Bronco project in the works so I'm sure I'll be on here a lot...
I work for Hellwig and am the main guy in charge of these Bronco sway bars so hopefully I can answer whatever questions you have and update the kit with any comments/concerns I hear on here.
We did test fit it on a vehicle with the stock steering box/pitman arm. Here are the pics:
Flat ground, full lock
Ramped, full lock
Our test/project vehicle
blazinchuck
lightnin, can you post some pics of your bronco flexin some with or without sway bars mounted? a lot of ppl are interested in this...please post more pics
tim70
SF Bay, CA
Would it fit stock height or a mild lift, like 1-2 inches?
