Rebuilding a 66' 9" small bearing 10x2.5 drum setup.
Got new (to me) backing plates from Nick @ NorthEastFordParts.
Got a full 10x2.5" drum rebuild from Bronco Graveyard.
The shoes DO NOT fit on these backing plates. See photos. While the shoes measure 2.5" across they sit 1/4" (or more) high on the top post. You can see light underneath them.
I need part numbers for the correct shoes (from all the normal chain stores as I want to drive wherever it takes to get this stuff TOMORROW)
I did quick measurements with Nick (on the shop floor) when I called earlier but later I remeasured on a semi flat bench. The backing plate sits up on 2 bumps (one of which is for the ebrake cable) as well as the bleeder nipple on the brake cylinder.
I then remeasured with the cylinder loose and the 2 bumps hanging off the edge of the bench so it was flat and got a much different number.
Also I need 2 sets of the bake shoe links or wheel cylinder pins. I've heard them called both. Part numbers greatly appreciated.
See pics attached.
L.R.
See pics attached.
L.R.
