help a newb on a 72 purchase
Cheeop
St. Louis
[/IMG]
Hi eveyone. i've been stalking the forum for a while in anticipation of getting my first EB and now that i've found one I had a few questions.
i'm fairly mechanically sound growing up working in my family's hardward store and hanging around my grandfathers body shop but I want to make sure i'm not getting into anything i can't handle.
Its a 72 and here's the description:
Quick run down on the Bronco:
- 302 bored .030 over with Keith Black pistons, Lunati cam, World (same as Roush) heads, and Edelbrock intake
- 3 speed on the column
- Manual brakes and steering
- No dents other than the normal little dings that a 41 year old vehicle would have
- No Bondo that I've ever found, previous owner put floorpan patches in
- Has one spot of rust about 1.5" long in the seam on the drivers side fender and some surface rust in the gutters on the top
- Front seats have fairly new covers, but back seat has original cover on it so they don't match
- Biggest issue with it is it is due for new gaskets around the front/rear diffs, transfer case, and transmission
-Cut rear fenders with fiberglass flares and original uncut front
-Interior Rear Roll bar.
-3.5" suspension lift (not sure of brand but thinks it a cepek. i didn't know they made EB lifts, possibly just used cepek shocks?)
its a 72, that was repainted in 2006. It has almost no rust from the many pictures i've seen and speaking to the owner.
I'm concerned about the drive train leaks? how big of an issue could this be and what should i be looking for when i test drive it?
I've got this bought for $8k and a decked out Rock River ar15 in trade ($1750 value) which seems fair but i'd like your opinions?
thanks in advance
Bronco Junkie
So Cal Broncos
Welcome!! In my opinion the biggest issue on Bronco's is the rust/rot factor. It seems like you have found a fairly rust free vehicle....changing some gaskets to fix a leaking drive train is minor...esp if you are saying you have some mechanical skills. Got any pics??
Cheeop
Cheeop
St. Louis
Pics added. don't know why some are really small? i linked them all from photo bucket.
The engine bay is really clean as far as wiring hoses. It's completley painted same as exterior color. interior front seats have been reupholstered and bench is original. The dash and doors are all very clean and all guages work except for fuel which just quit working about a month ago supposedly but that's not a big deal. He said the ebrake light stays on when the head lights are on?
bmc69
Welcome!
Some seepage in all the areas you listed is pretty much "normal". Are any of the areas you identified actually leaking to the extent that they leave a spot on the ground or garage floor when parked for a few hours after driving it? The owner should be able to answer that easily..by pointing to where the truck is usually parked is one way.;)
I degrease and power wash the entire driveline of my trucks at once a year. Besides keeping things looking better, its the best way to be able to spot real leaks sooner rather than later.
Cheeop
Cheeop
St. Louis
thanks! i'll know more hopefully this week on the extent of sepage. Say it is to the point that there is a spot on the ground, or even a few, how concerned should i be. if it's just leaking and the 4wd works and there's no crazy sounds coming out of it, I think i'd be safe to assume its just the gaskets?
Bronco Junkie
So Cal Broncos
I would not worry about a few spots on the ground....rear main seal almost always leaks...and if gaskets are old...they are going to leak. If you need to add oil every week to keep it full...well then maybe you want to consider changing some gaskets. If all you got are some oil spots on the ground...and you think the rust factor is OK....seems like a nice truck to me.
bmc69
^---what he posted. ;D
tcb-1
Shawnee, KS
Just bought my first too, so welcome aboard! Like many have said, leaks are normal. However, mine leaks less than my Harleys :)
8k and an AR for a fairly rust free eb is money well spent, imho.
edited 'cause I can't read Xp
addicted
Broussard, Louisiana
I really wouldn't worry about leaks. Just make sure the body is in good enough shape for your liking. Rust and rot are the most expensive things to fix and the biggest headache. Its actually a good thing that it was painted 6-7 years ago because any "cover ups" should be showing through by now if they weren't fixed properly. Mechanically these trucks are super simple. I rebuilt my entire transfer case for the first time with simple tools and advice from members on here. Came out perfect and works flawlessly. If everything works properly but you have leaks then changing gaskets is a snap.
astronot
Llano, TX
I must have read the original post wrong . . . You paid $8k and got that EB AND a tricked out AR???? You must be some smooth talker!
Cheeop
Cheeop
St. Louis
Unfortunately I was on the giving end of both the AR and the 8k. It's a sweet ride though and I needed to thin out the gun collection a little anyway (never thought i'd say that).
thanks for all the advice! it's exactly what i was looking for.
astronot
Llano, TX
I don't think there's anything unfortunate about it! You've got a pretty cool EB at a fair price!!! Have fun!
Cheeop
Cheeop
St. Louis
We'll I pulled the trigger today. 8k and an AR and now she's mine. The front and rear differentials had seepage but the trans looked like it had a little more than seepage, kind of a very slow drip. The PO said he added trans fulid about once a year but it hasn't ever left a puddle in his drive. Added bonus, he has the original spare tire carrier for the back also along with all the reciepts from the engine rebuild, lift and paint in 2006. No rust as described but I think it had all been repaired in 06 when the paint was done and someone did a good job becuase the floor boards had been replaced but i saw no sign of serious rust anywhere else. Couldn't be happier. i've already ordered a power brake kit and will be installing that as soon as it comes in.
thanks for the advice
