HELP! AWD 4r70w dimension needed
NM_outdoors
Happy Sunday all. I'm looking for the VERTICAL distance between the crossmember mounting surface on a 4r70w (AWD tail-housing) and the bottom (or top?) of the frame rails. My tub is off and I need to get a crossmember built.
Will be running a 2" body lift but trying to work around a clearance problem between my JDuff radius arm bracket and Atlas II. Any help would be MUCH appreciated!
NM_outdoors
NM_outdoors
Trans mounting surface is sitting about 1.5" higher than the top of frame rail in this pic. I'm guessing it needs to come down about 4"?
NM_outdoors
NM_outdoors
Trying to do this without putting the body back on just to check for clearance.
NM_outdoors
NM_outdoors
Another pic........
ponypower77
Just measured the cross member mounting surface on my 4r70w (AWD tail-housing) and the bottom of the frame rail is 3 inches below.
NM_outdoors
NM_outdoors
Thanks ponypower! You just saved me a bunch time putting the tub back on the frame. Looks like you're running a 1" BL on that rig? You good on clearance with that combo? What part of the Land o' Entrapment are you in?
NM_outdoors
NM_outdoors
Here's a good article that describes the correct way to do drive train
offsetting.
http://jniolon.clubfte.com/drivelinephasing/drivelinephasing.html
Looks like my original thoughts of rotating (for T-Case clearance) probably would have caused problems. Now that I know the vertical location of my drive train axis (thanks again Ponypower77), I can see how much room I have and either offset everything or drill/tap the T-case to clock it for more clearance. Unfortunately, that will also mean it's going to hang lower...... but that's probably where I'll start.
ponypower77
Yes, I have a 1 inch body lift on the bronco. For clearance I have lots of room except at the transfer case, it is about a quarter of an inch from the floor. I am just south of Albuquerque.
NM_outdoors
NM_outdoors
I'm between S-Fe and Los-A. Look me up if you're ever in the area. Would like to get some feedback on your 4r70w setup.....
Spending some time this weekend using your number to build a temp crossmember.....
