Here is a little background.
Bronco rebuilt about a year ago
New proformance 351w with mass flo efi.
new Mallory dist. and Mallory coil
New painless wiring
New BC tank with fuel accumulator.
Everything on my bronco is less than a year old. The only thing I have had to fix since the build was a bad starter just before I put it away for winter.
I just started having this problem after I broke it out from winter storage. .
After about 15 min. of driving it will stall. It does not sputter or anything like that it just kills the motor. If I wait about an hour it will fire right back up run great and then after about 15 min. it does the same thing.
When it stops running i still have power and everything will work. Starter will crank I can hear the fuel pump and I have 40 pds of fuel pressure but it will not fire for about an hour. So far I have replaced the following
New MSD coil
New TFI module (grey version) original was black
Still having the same problems
Any help would be greatly appreciated.
New painless wiring
New MSD coil
