RedLeg0811
This is what my roll cage looks like now. What you can see is the tube going from the B to the C pillar for the rear seat mount. I am also going to put tube running diangle from the upper B to the lower C pillar. I will also put two middle bars running from the cross bar of the A pillars to the B pillar. I will also be adding gussets.
What I am not sure about is I thought I was going to do the same and run two middle tubes from the B to C pillars. Looking around at different roll cages that are like mine I don't see those middle bars in the rear section of the cage. Is there a reason for this? Is it going to be strong enough already?
Martin
Martin
