Help identify some wiring
blazinchuck
Installing a Ididit tilt column in what I think is a '70 bronco. Fuse panel in on firewall by gas pedal.. there were two connectors from original column. Someone has removed the washer and horn wires under the hood...planning to rerun these also.can't really find anything on these older broncos. Found charging and turn signal wiring...but nothing on the column or other wires.
Big connector has yellow, dual red w/black,blue w/yellow, blue, and dual greens and dual whites for turn signals.
Small connector has a yellow and a lite green. Thanks for any help,Chuck
Sent from my HTC6535LVW using Tapatalk
blazinchuck
blazinchuck
Here's the connectors on the column
Viperwolf1
electron whisperer
Blue=12v from turn flasher to turn switch, circuit #44
white-blue=right front turn and indicator lamp, circuit #2
green=right rear brake and turn lamp, circuit #282
green-white=left front turn and indicator lamp, circuit #3
yellow-black=left rear brake and turn lamp, circuit #283
red-black=12v brake switch to turn signal switch, circuit #810
yellow=12v headlight switch to horn switch, circuit #460
blue-yellow=horn switch to horn, circuit #482
blazinchuck
blazinchuck
Thanks viper, that last image...is that my connection to the column wires?
blazinchuck
blazinchuck
OK cool, one more...this has a emergency switch on dash, was gonna wire up the new column hazard switch...which wires. That brown and black?
Viperwolf1
electron whisperer
Just run the output of the haz flasher (white-red wire) to the brown wire at the column.
Black wire is for horn. You will need to add a horn relay. Use the black wire as a ground switch to turn the relay on.
blazinchuck
blazinchuck
Thanks again! Can I use the 460 yellow for the new horn relay power? Or would the 482 be better?
Viperwolf1
electron whisperer
460 to relay terminals 30 and 86
482 to relay terminal 87
black wire to relay terminal 85
blazinchuck
blazinchuck
I was just gonna use the horn relay from Ididit. That's why I was thinking one of those could be used as power
blazinchuck
blazinchuck
How can 482 go to horn? Thought the horn had a green wire or something...like I said. The wires for the horn and washer pump are missing. PO ran a universal horn button...I removed all that mess
blazinchuck
blazinchuck
I was just gonna run wire from that horn spot. On relay to the horn. Yellow for power and black for its ground
Viperwolf1
electron whisperer
Well it used to go to the horn. Washer pump wire was green-black.
blazinchuck
blazinchuck
OK thanks for your awesome knowledge viper wolf
