- Mar 30, 2004
- 713
So I have this pair of bare heads which I received along with short block 302 (they were loose, and I re-used my semi-tricked-out old ones.), when I purchased it in 1993. How or where can I look to figure out what they are? I know nothing about heads, and I see some casting numbers inside the lower center, which would be hidden by the valve cover. One has a "302" cast into it. One has a "Ford" script cast into it, the other looks like it has a tag which says "B A" covering the "Ford" script.? Could this have been rebuilt by "B A"?
The first head has "4E24", and a "S", and "Ford", and "WCP"(although not in that position).
The second head has "4E29", and a "CF" looking cattle-brand, a "302", and instead of the "ford" script, it looks like there may be a tag over it saying "B A" There is also a "6A" down where the lower part of the head meets the block.
The valves and spark plug are located in a hollowed out "bean" shaped chamber, not a hollowed out "circle". Hope this makes sense. So what have I got?
