67sport
Member
What are the symptoms of old t-case mounts?
I'm trying to find a clunking sound, that occasionally comes and goes from the rotating mass of my 67. Sounds like heavy metal object against heavy metal object.knock, knock.......knock....knock......,,,very irregular. And not always present at all.
'67 with 302, original 3.03 with husrt floor shifter, original d20.
What I know;
It's not connected to the rolling assembly, it does it sometimes when stopped at idle, so can't be driveline.
It has done it through 2 exhaust systems, this one has good clearance, nothing contacts it,
It has done it with the original 289, and does it with the current 302, new motor mounts installed,
I don't believe it's in the motor, it has done it through 2 motors.
I have a new TW driveshaft and new rear end, so it could be in the t-case, but can't be slop in the rear driveline.
I have never pulled or separated the trans/t-case and have what I believe are original bushings. I salvaged the truck 25 years ago, I don't believe they've been replaced ever. They both shift well though.
What it might be;
Loose motor mounts - I have tried to pry the motor, mounts are new-ish, I need to check the torque, but I don't think so, they don't move with a pry bar.
20 year old Duffy headers against starter - very little clearance, but should move in phase with each other, I don't think so. Headers are in good shape.
Clutch/flywheel assembly - possible, but over the years, if something was loose, it should have let go. Also, 2 different motors and clutches, so unlikely.
Internal trans or t-case issue - maybe? Any input here? They both work well.
Old rubber t-case bushings - I hope so? Seems most likely, but I don't want to throw parts at an undiagnosed problem. When I pry at the t-case, I can hear the rubber bushings squeak and see it move, but the whole assembly looks really good.
If its the t-case bushings, should it go away idling with the clutch in? The internals are disconnected at that point, but arent the engine/trans/t-case still vibrating together?
Anyone have ideas on where to look/diagnose, or how to test the rear supports?
Thanks for the input. It's done it for 25 years. It shows how far the truck has progressed, now that this is the problem I'm trying to fix! The truck is finally working great!
Sent from my SM-T560NU using Tapatalk
What I know;
What it might be;
