blubuckaroo
Grease Monkey
If you're trying to decide between 31", 33", 35"... you also need to consider your axles, gear ratio, and brakes. Gear ratios are easy, but brakes are taxed by taller tire diameter. Also, the traditional limit for 28 spline axles is 33" tires.
