- Nov 11, 2007
- 8,008
I rebuilt my D20, how deep to go to make adapter work?
So the v8 explorer 98-01 then for a 4r70w?
Yes for that transmission.I rebuilt my D20, how deep to go to make adapter work?
I'm no expert (I have an Atlas, duh) but IIRC if you have an awd version you dont have to change the tailshaft housing. AA used to sell an option (I dont think they show it anymore) that used the ZF adapter ring with the correct spud shaft plus a seal carrier, simpler than changing to the custom AA tailshaft housing. And i don't believe any D20 disassembly is required.
You read my extensive write on the 6r install?Hi all, finally getting close to getting the barn queen driving again. My winter project, Currently, very nice NV4500 behind a 347 SBF out of an explorer. Carbed. Stock D44, 1.5 SL, 2 inch BL. Explorer serp and stock radiator which has tranny cooling ports.
Been reading a lot in the tech forum, my decision is the the 6R80 still seems unrefined compared to the 4R70 swap. I really want the 6 gears, but not if it means months of fab work. I know, some of you would have it done in a day but thats not my life these days, nor my facilities to work in. I really want to buy it all, bolt it up, and install, with little fab besides exhaust, maybe new driveshafts.
Things that are similar between the two: both need a controller, both need driveshaft checks or new ones., floor shifter, possibly twinstick modification for stock D20. Exhaust change, probable removal of torque tamer along driver side inner frame rail to rear end.
Differences:
4R70, more plug and play, fits better. Cheaper, but not by much.
6R80, probably front driveshaft fitment issue. Definite lift issues, some kits noting 2.5 inch suspension lift needed, not really understanding why, other than tranny pan to driveshaft problems. Odd adapters to get modular tranny to SBF.
Lastly, long term goal, install EFI. Should I do that before attempting a shift controller, or can that be changed from carb to EFI without cost?
I am leaning 4R70. Prove me wrong, or right
Love the NV4500, but wife has some knee issue, and don't want a one driver vehicle.
That adapter is what I ended up with designing after building quite a few of the early style that needed a bit of alum bellhousing removed because a stock starter was used.WH kit eliminates the speed gem and other guys adapter kit.
I'm good i have the nv4500 in there with a 2 BL thanksYou read my extensive write on the 6r install?
The 6r is a lot taller that's why a small body lift or tunnel mod is needed.
I have several in the shop. If you want me to measure it from the cross member to the top of the bell housing area or from the bottom of the oil pan to the top of the bell housing area, let me know.
Agreed. Part of the reason they last so long in factory form is in the programming. There is a feature in the factory programming for torque reduction. What it does is it cuts timing to the engine for a split second while the clutches engage to reduce wear on them. It's hardly noticeable but prolongs the life of the trans greatly. The drag racing guys will shut it off but I think its a great feature for just about any other kind of use.By the way, I would always advocate installing new parts over junkyard. However, I have it on good authority that these trannies are really quite hardy and know plenty of guys installing and running them with 150K or more without issue. If your sticking it behind a stroker and racing like Lars does is one thing. Behind a 5.0 going for ice cream is whole other thing.
The tuning that goes into that is good stuff. For the most part, shifts are super quick. Not like the old C4/C6 days where the clutch pack will slowly engage for a smooth shift. Since the engine torque never changes during the shift, but the general public wants smooth shifts, the clutches take a beating. And often why those old transmissions needed a rebuild at 60k. The RV/Tow shift kit took that smoothness out and made a quick shift. Since the clutches only have a small window of slipping while engaging they don't take as much of a beating. While at it, the overdrive transmissions that got a bad reputation for burning up when towing, "always turn the overdrive off while towing". That was the clutches taking a beating as the trans hunted in and out of overdrive, generally at full engine torque. Gear high for economy and it has to hunt while towing. The shifting is what fried the overdrive transmissions during towing, not the actual towing. Get into the "don't fear the gear" and be able to pull most grades without downshifting, transmissions will be happy. Even towing in overdrive.Agreed. Part of the reason they last so long in factory form is in the programming. There is a feature in the factory programming for torque reduction. What it does is it cuts timing to the engine for a split second while the clutches engage to reduce wear on them. It's hardly noticeable but prolongs the life of the trans greatly. The drag racing guys will shut it off but I think its a great feature for just about any other kind of use.
Yeah, you'll like it. I probably run mine 90% of the time in full auto mode.Nah full auto mode for me in this thing, no need for lock out and such.
I run my 4R in auto on the pavement and and smooth gravel roads, and in manual for wheeling. Pretty hard to beat.Yeah, you'll like it. I probably run mine 90% of the time in full auto mode.
Which trans are you referencing?Yeah my tranny place on Washington by 44th that I have been using since the 70's can rebuild one no core OTD about $1,800. Just talked an he already knew it needed the v8 4x4 valve body.
