Help me pass DEQ...failed CO
JSmall
76 302 w/ edelbrock 1406
-Fresh carb rebuild
-No smog equipment and no catalytic converter.
-New plugs, wires, cap and rotor
-Fresh oil and gas
HC - Pass is 300, mine 158 so I'm good there.
CO - Pass is 2.5%, mine 5.9%
What would cause the high CO levels?
High CO = running rich
Surprised they even tested you without a cat in place
JSmall
JSmall
That's what I thought, but they didn't care. The guy actually put in the system that I had a cat present so the numbers were much lower for passing. HC 220 and CO 1. They checked and it didn't have one so he scribled out the HC and CO standard and replaced it with the standards without cats, which is HC 300 and CO 2.5%. If I would have met the standard without cat, I would have passed.
Both techs took pictures of my Bronco so maybe they let it slide...I'm not sure.
JSmall
JSmall
Here is what I'm talking about
broncnaz
Sounds like the techs were being nice. as usually 76 broncos will be required to have cats no matter what as its considered a crime to remove them. but anyways. High Co is usually due to bad AF mixture meaning some thing is wrong in the carb. Although first I would make sure your igintion timing is set to the stock spec. 6 degrees. then adjust the idle mixture screws so you get the highest steady idle(a vacuum guage helps here). Might also check your float level and make sure the choke is fully opening also make sure the engine is at normal operating temp before starting the test. Id suggest having a 190 degree t stat. to make sure its at a good temp.
Quick & Dirty
HC is ignition misfire, or very rich.
CO is slightly rich.
It looks like the test was at idle, so lean the idle mixture out, but not so much it misfires. For best emissions, it may need to be leaner than where it runs best. Reset it for best running after the test is passed.
JSmall
JSmall
I think it will pass when I go thru DEQ tomorrow. I had a massive vacuum leak at the brake booster. The mechanic capped the vacuum line that runs to the booster and tuned the carb. I have manual brakes right now, but I'm fine with that if it means passing.
I need to finish gathering parts for my hydro boost swap.
