help- parking brake
OneTonGoldfish
san marcos, tx
I need to hook my parking brake up so I can pass tx inspection. all I have is the pedal assembly which is in good working order.
there are no cables or brackets/levers under the bronco. This is what it looks like at the brakes. Someone just cut the lines.
Now, what would be the cheapest option? Is there a way I can rig it up to just one wheel? Like I said, this is just to pass inspection so it only needs to be able to hold the vehicle in place...
parts from a vender would cost about $200 or more. maybe someone has some used parts..
robofig
I used a set of e brake cables from a 78-79 bronco. $15 at the junk yard. They are a little longer than eb cables which helped with my 3.5" lift.
SSDDBRONCO
Los Angeles
i have no parking brakes as well what would i need to set up a parking brake? Also i was thinking about doing a hand parking brake instead of a foot parking brake. Any one ever do this?
barronj
I'm sure you'll find that a hand brake is preferred by crawlers, if anyone. I bet there are a few people who've installed them on their trail rigs. I want to say I've read that here before.
OneTonGoldfish
OneTonGoldfish
san marcos, tx
anything that will cost under $100 would be great!
oh ya, I have a 5.5" susp and a 3" BL for what its worth. maybe a parking brake from another vehicle will fit
66fora69er
I pulled a full width 9" out from under a 79 f 150 and the parking brake cables looked similar to the ones under my eb. probably longer. Those trucks are plentiful in the wrecking yards. good luck
StnePny
Santa Monica, Ca.
I will speak like a White Man (Thanks Ted Neuget) They butcher that like a mother fucker ...
Take the wheel off, the drum off. disconect the little ding-bob, put the Rear Factory E-Brake cable on to the Center Pivot Point and your pedal will work.
