bcmbcmbcm
Hey folks. Can use some help sorting out the EFI hose plumbing under the hood.
I am looking at the pressure-inlet hose to the front of the passenger’s side firewall. I did not see a hose clamp there. Is there supposed to be one? This is a BBK fuel rail. I cannot tell from the pics if these are spring lock connectors but I have a feeling they are not. Is this a problem?
Also, the feed line (it’s the feed line that attaches to the passenger side fuel rail at the front of the car, correct?) runs close to the passenger’s side inner fender. I was going to secure it down with some clamps and move it away from the wires. What are your thoughts about putting a fuel filter there? Or is it better under the vehicle? I was going to use Dorman 800-119 which will adapt the 3/8 EFI hose to the 5/16 connector on the factory Fox Mustang Fuel Filter. I was also going to have a Fox Mustang filter mount modified to fit either the frame or inner fender.
My thoughts on the inner fender would be that I would inspect it more frequently for leaks, like every time I fill up with gas or just admire the engine. Then again, I have never had a fuel filter leak, ever. I suppose I am concerned about the 3/8 line to the 5/16 Dorman adapter.
Brett
Brett
