Help with chassis modification
SanFarnLos
I'm in the process of purchasing this 1970 ford bronco. the chassis has been modified to make room for a transfer case 4x4. I added the picture on the photo galley. You will see the frame by itself. I need some advise if this is something that would bring down the value of the vehicle or if it would make it not worth the same, Any advise if greatly appreciated.
Steve83
After you've uploaded a photo (anywhere, or found one online anywhere), right-click it & "Copy image address" into your computer's clipboard memory. Then paste it into your post here between [ im g][/i mg] tags (without any spaces) to make it appear like this:
Yes, that reduces the frame's value from ~$200 to ~$0, EXCEPT when it's under an assembled & running truck.
Hey SanFarnLos, welcome to classicbroncos!
Are you paying a premium for the complete rig, based on the equipment that's installed? Presumably it's a later model transfer case attached to perhaps later model engine and trans?
If so, then as Steve said the value is still in the assembled Bronco. Is it what you want? Then great, you'll pay extra for the modifications that it has had to go through to achieve what you wanted.
If it's not what you want, and you're going to try to put it back to stock for that original look and feel (which I think would be a mistake at this point), then it's not worth a premium to you because it will take a lot of extra time and/or money to put it back the way Ford made it. For limited value change perhaps.
It's all about what the next buyer wants. You can try to predict what the market will be two, three, or ten years from now, or you can enjoy what you get while you play with it.
Now, if it was all hacked to death to make some strange mix of parts work, then there is no enhanced value in the mods to begin with. If someone you're trying to sell to wants an original, unmolested barn-find, then you're looking at the wrong Bronco already.
The future value is up in the air. What it's worth to you is what's important right now.
If it's done well by a professional, and it runs like a top, handles like a dream, and looks great, then for at least some future buyers the value is only raised.
Right now it's not originality that sells Broncos as much as nice new shiny paint. Unless it's a truly original survivor that can actually be driven safely and enjoyed in that condition, or unless it's some rare version of a Bronco, most buyers don't even care if it's the original color or has the original engine at this point.
It's not the muscle car market for Broncos, and there is no such thing as "numbers matching" on Broncos either.
So again, it's all about first what you want, then in the future what the next person wants.
Are you familiar with Broncos from experience? Or just wanting to have some fun with a cool vehicle that might still be worth what you paid for it four or five years from now when you want to try something different?
Both schools of thought work, but your enjoyment level might plummet if this is your first older truck/utility vehicle and you are intending to drive it much.
Good luck no matter what. Let us know some more details about what you're expecting and how long you intend to keep it, and we can probably give you more advice/opinions.
But Steve pretty much put it in a nutshell already. A Bronco frame alone has always been worth "not much" to begin with, and "even less" to 99% of the people when it's modified.
SteveL
Huge chevy guy
Hawthorne ca
What t-case was he trying to fit? I've seen guys notch it a little for an atlas or 205 swap but nothing like that.
I've only seen that kind of butchery for fitting a NP208 or one of the BW cases. Late model chain drive stuff.
S
SanFarnLos
I added more pictures on the gallery forum to show why they did this modification. Now would I be Abel to change out the frame and put a new one? Or would this devalue the vehicle. This is my first bronco and I will be using it as a weekend car, but. I do want it to have its resell value when I decide to sell the vehicle. I also added a picture of the bronco it’s the black with white.
Steve83
If you put the actual JPG addresses inside image tags [im g]URL.j pg[/im g], they'll be easier for everyone to see.
Yes, that's an '87-96 BW1356 behind (probably) a Mazda M5OD-R2.
If it runs & drives, there's no reason to mess with it, no matter what it looks like underneath. For that level of frame butchery, it looks like it was done pretty well.
Nice looking Bronco. Is it fully assembled now, as in the street pic? Or is it in pieces and being built in the shop at this point still?
What other details can you provide? Judging by just what I see in the pics though, it's not being built for resale value. Just for fun.
Yes, it's the much larger later model transfer case that nobody tries to put in their rigs anymore for just the reason that you're experiencing here. Major modification to the frame so it fits. Nothing inherently wrong with the gearbox itself for the street, as it's a quiet and reasonably efficient chain drive unit. Not desirable at all for off-roading however, even with it's semi-low gearing, it's been considered a weak link if I remember, for the hard core off-roaders. Not many of whom are buying Broncos these days, and it doesn't sound like that's what you're wanting either. So it's still back to the mods.
What about the engine? Kind of a mix of stuff there too. High-rise intake maybe? Do you know what the specs are on the engine? How much cam, intake and carb?
We can see that it's too much of the wrong exhaust right off the bat though. Dual exhaust is still somewhat popular, but not near what it used to be, simply because Broncos just don't have the available real-estate for it. And the one in the pic is full dual without any kind of a cross-over, too large of tubing, and too small in the muffler department. Not to mention the cheap and undesirable way out of a dilemma, the dreaded turn-downs ahead of the rear axle.
Some here have that setup, but most hate it when it comes right down to driving on the street. Too loud for the neighbors (if that's an issue), too much drone (most likely), and too much heat into the floor boards especially on the passenger side.
None of which is a deal-breaker or to be considered an insurmountable obstacle, but it's not stuff you pay extra for either.
Since there are a lot of Broncos still for sale out there (don't let anyone tell you they're "super rare" because they're not. There weren't as many as most other vehicles, but right now they're coming out of the woodwork and every rust-bucket beat up Bronco that was ever sitting in a yard for ten years is coming up for sale. You can get some super sanitary fully built and ready to drive rigs for $30k to $40k. Probably some in the classifieds here, and for sure on the Craigslist pages.
If you have one built to spec though, you're into the hundreds, if not multiple hundreds of thousands of dollars. Just like any custom hot-rod build at a shop, you pay to play.
We have several members here that are custom Bronco builders of the highest caliber and honest about every aspect. Nobody's getting screwed by these builders. But they are paying a lot of money they won't automatically get back at resale time. Most are probably building to keep though, which is why they've chosen these particular people and are willing to wait a year or two in line for their chance.
So is it your Bronco at this point? Or are you looking at it to buy soon?
And to my previous question, is it done or is it still in the shop being worked on?
Now back to the value bit.... Right now Broncos are hot as I'm sure you've seen. But just as with previous "hot cars" the only ones who are making money on them are the ones who buy cheap and do their own work. Otherwise NOBODY that has one built by a shop makes money on one. Nor can they expect to recoup their investment later.
Just like the hot-rods that cost $100k to build and are for sale all the time for under $30k, a Bronco is the same thing.
You might pick up a needy one for $5k (if you're super lucky!) then spend $60k having someone give it the basic fixer-upper job. If you tried to turn it around right then and there, you'd probably get the same $30k for it.
Just some more food for thought. In spite of all that they actually are a decent investment right now. But not an investment that automatically makes you money when you go to sell. Just one that pays off in fun for now, and a smaller than normal loss later.
It's all about the individual circumstances... Some still get lucky.
You can see in that shop pic the reasons many of us have changed from the old dual exhaust to either a 2-into-1 single on the passenger side, or even a dual system but both run down the passenger side.
Right behind that left side muffler are the reasons, in the fuel pump and filter and lines running right up the inside of the frame rails. Right beside the brake line and wiring harness!
All not liking excess heat, and all sandwiched right there by the exhaust. Very tight clearance too by the look of it.
Look beyond the shiny paint. I am also seeing stuff like the PCV hooked up to the air injection for the cylinder heads. From what I have seen so far this one will leave you a long term history of trying to figure out what they did.
There is good stuff like a Carter P4070 fuel pump at the back of the frame. A rear sway bar.
