rbwamsley
- Mar 24, 2014
- 221
I recently picked up ’74 bronco, and I’m having issues diagnosing an issue. I have oil coming up out of the dipstick tub. Based on the knowledge of the previous owner, the engine was rebuilt a few years ago (everything looks stock to me, but this is my first bronco). When I first searched the issue online I came to the conclusion that it was the PCV valve and was an easy fix. I’ve tried the following to remedy the issue.
The PCV setup looks correct to me. Here’s a pic.
My next step is to do a compression test on each cylinder and check the plugs for oil.
Other symptoms that may/may not be related:
I would appreciate any help or suggestions you guys could give me.
Thanks,
Blake
- Cleaned the PCV valve and made sure the valve could freely move.
- Changed the PCV valve (It was a smaller than the original, but it’s the only one I had laying around the house)
- Changed the oil (thought the previous guy may have put too much in it, and the dipstick could have been aftermarket). This made the issue much worse but only because now there was 6qts of oil, where I had only drained 3qts.
- There was some oil on the air cleaner plate. It looked old and was lighter in color.
- The engine seems to idle high and drop down to a “normal” rpm when put in gear. I’m not sure if this is an issue or not, as this is my first automatic carbureted car. I’ve read that this could be vacuum leak. If I remove the vacuum line from the carb. the idle drops down to a “normal” rpm.
Thanks,
Blake
