Help with gas gauge!
redneckrocky
Austin, TX
My gas gauge just quit working, and now I'm wondering if I have enough gas to get anywhere. I was wondering what you folks would check first, electrical problem, mechanical failure, something I am unaware of that will fix it without a lot of work or money (although I am aware that this is almost impossible for a bronco). Thanks in advance.
70TEXEB
Abilene, TX
I know you will get some better detailed responses on this. But everytime I have problem with my fuel guage its always the ground wire coming from the tank. It dosn't cost anything to check. So it is always my 1st.
72bronco
The problem could be your guage itself, the wiring, or your sending unit. I agree with 70TEXEB that you should first check the wiring. If you have a loose ground wire then your guage won't work at all.
cracker
Pueblo, Colorado
I am in the process of fixing a bad gas gauge as well. I have ruled out the sending unit, by taking it out and using my ohm meter on it. I have ruled out the ground wire, by taking it off and re-grounding it. I have a problem either in the wire to the gauge or the gauge itself. One item of note, the gauge works on occasion, usually after a day of wheeling where I have hit "something" pretty hard and jolted the EB. I have tried grounding the wire to the sending unit, without any changes, so I am going o re-wire the gauge first. If that does not work, I am going to replace the gauge......... %) The joys of owning a vehicle with almost 40 year old wiring...
stevew
Elliston Montana
Check 1st if theres power to the sending unit . Use a test light . If it has power then theres 4 things , the gauge , the switch if dual tanks , the unit itself or the float . I've replaced 4 floats alone this year . They become porus & fill with gas .
Jeepster
Where did you get the floats?
ManTruck
Install a jumper across your plug that goes to the sending unit. I used an alligator clip. Have someone watch the gauge, or position yourself to watch the gauge. Turn you ignition switch on, but not for long. If you have the two female leads jumpered together and the switch on, the gauge should register. If it works your problem could be in the sending unit or the ground. If you get nothing your problem is in the gauge or a connection between the tank plug and the gauge.
I had a couple of wires placed incorrectly on the back of the gauge and the tank switch on the dash was wired wrong also. It took me about 30 minutes to trouble shoot this. This did not just start, it had been that way for a while due to some bad install by little ole me years earlier.
Your case sounds like a ground or a gauge.
redneckrocky
redneckrocky
Austin, TX
Thanks for all the help. Now I just need more time to try things. I checked the ground and it seems ok , so I'll just keep on trying this stuff. Thanks again and keep it comin'.
jbeyer
new york city
clean the rust off the sending unit contacts. if you have dual tanks, check the switch. that was giving me intemittant fuel gauge problems. bump-it works. bump- its broke again.
