GAS GAUGE HELP, I know, sorry
Bartonatl
Atlanta
Sorry for yet another gas gauge question with all the old threads, but mine just does not add up.
1) gas gauge does not register. Can't get a response when the hot is grounded. yet it should work, because it has 13 ohms. Everything I read says that if some of the gauges in the cluster work then the VR is ok. I do have gauges that work. What should the power to the gas gauge be? Is the power coming from the black-yellow wire? The orange wire goes back to the sending unit.
2) my main tank reads 74 ohms, full. that means leaky float, right? Or it could have been installed upside down?
Thanks for the input. Don't want to run out of gas in Townsend this weekend.:D
oleguy74
calif city ca
orange wire to main.yellow to aux.power comes from IVR,to gauge,to sender.73 ohms empty,10 ohms full.if you remove wire (hot)at tank and ground it gauge should go to full.
blk/yel from IVR is hot.if temp and oil work IVR is ok.
Bartonatl
Bartonatl
Atlanta
got it.!! Aux fuel tank is working, guage is working.....
Main tank still reads zero. I'll keep working on it but I think I understand it now.
However, I now want to install the tank selector switch. I have two tanks and a tank selector valve but there is no hole in the dash for the selector switch....??. Shouldn't it go to the left of the steering column?
BNC04
Longmont
I believe the switch on the left of the dash, Switches the gauge to read from one tank or the other, the fuel selector/tank switch is usually located in front of the drivers seat just off the floorboard. this controls what tank the fuel is delivered from.
Brett
Bartonatl
Bartonatl
Atlanta
yea, The selector switch under the seat is there and I cleaned it. I got my gauge working. Now I'm wondering why there was no gauge selector. A bought a selector. guess i will just drill a hole in the dash for it...to the left of the steering column. Am I missing something? Where is the original whole?
