EBGeek
- Nov 25, 2008
- 411
Good morning, all. Quick backstory - I've replaced virtually every component of my steering system in an attempt to make my EB as highway friendly as possible. From new steering column, steering shaft/joint, rebuilt PS box by West Texas, high caster C-bushings, steering linkage + stabilizer to new (Moog) ball joints.
I initially purchased a Bronco Graveyard steering linkage and drove with it for a while, but was very disappointed as it flexed quite a bit (which I believed was making my steering sloppy on the road). I ended up then buying a $400 'heavy duty' steering linkage from Wild Horses and it was significantly thicker/rigid and I assumed it was going to drive like a dream after installation.
As of right now, I have probably 5,000 miles on the linkage. It drives/tracks perfectly when going straight...you can literally take your hand off the wheel and it will practically drive itself in a straight line. However, turning (especially in a curve) the steering is choppy/laggy and it has gotten progressively worse over time. I had my wife turn the steering wheel last night after an exhausting road trip yesterday and found the entire linkage is twisting when the wheel is turned.
See video attached. Any idea what causes this and whether or not there is a fix? I've spent nearly $800 on steering linkages at this point, and unsure if I should just opt to have someone fab one up with heim joints to tighten this nonsense up...
Any input from the pros here?
https://imgur.com/gallery/ovAQApi
