jason.k
Ok guys here is my problem. I have used #8 3/4" sheet metal screws holding my rear floor pan in place. So today I went out to the shop to practice my spot welding before I touched the bronco. I didn't have any luck. I got a good butt weld that I could not break it just bent the metal. Got a good plug weld and it held. Problem is I don't have either of those welds to do. My question is when you drill through 2 pieces of metal with the screws mentioned above I do not get very good penetration. I did 7 screws and they all could be pried apart with a flat head screwdriver. I repeated this process several times and adjusted head and wire speed with same results. I called my neighbor over to give me some lessons and he is a very experienced welder with a few builds under his belt and he couldn't get a good weld on this little hole either. So what is the technique you guys are using? The only way I got this to work was pull a screw and then use a much larger drill bit to drill the top piece of metal then I could get to the bottom piece and build up much like a plug weird. Any help is appreciated.
