MnkyBiz
All & this is focused at RRAAAAYYY also!!!!
Ok, I have a Mean-Green starter. I can't figure out how to electrically separate the starter from the starter solenoid!
There are only two wires external to the two units!
Here is the first, that I refer to as the "jumper", though I am not sure if it is the jumper or not!
The other wire is a 1/0 bundle on the other side, that comes directly from the top portion (I think that is the Solenoid) to the bottom. It is hard wired into the top & the bottom has a nut, but both are covered with a rubber boot.
Now back to the photo that I have shown! If this is in fact the jumper between the starter & Solenoid, I can disconnect it, connect the "+" of the battery & the alternator to the nut, and connect my 8 gauge wire to to a Female quick connector & then connect the other end of the 8 gauge wire to my Solenoid on the fenderwell.
If this isn't the jumper wire, then I haven't a clue as to how I can FREAKING separate these two units!~
Anyone....hheeeellllppppp!!!!
Mean Green has NO SERVICE TO SPEAK OF! YOU CALL & GO TO AN ANSWERING MACHINE THAT MUST NEVER GET LISTENED TO! HORRIBLE TECH SUPPORT!!!!!
MnkyBiz
MnkyBiz
