Hickey Sidewinder Winch Installation
76_fordbronco
I just purchased a Hickey Sidewinder winch for my Bronco. The Winch was originally on a 76' Jeep Cherokee. Does anyone have a layout for installing one of these on a Bronco e.g. drawings I can work from to build a mount?
Rox Crusher
I ain,t got no stinking drawings but I fer sure got a crappy Hobart welder that we can scap some welds with
;D
Viperwolf1
electron whisperer
Mike, I don't have any drawings but I do have the Polish blueprint.
76_fordbronco
76_fordbronco
Thanks Phil, I was looking to see if anyone had specific plans before I spent a lot of time doing some work someone else had already done. I hope to see you tomorrow at Rox's. I should be there after 4:30 PM.
CJ who???
Banning, Ca...
I have a Sidewinder winch that I plan on mounting on my Bronco. It was mounted on a 20' flatbed trailer that a bought.
I've never heard/seen of them before I ended up with one.
Did Sidewinder make different sizes of these winches ?
If so, how do you determine the sizes ?
YNOTBOB2007
I have one also & told by the P.O. that there is an oil hole on top that is only accessible with the winch dropped. Can anyone verify this?
Viperwolf1
electron whisperer
There was a mini sidewinder rated at 8,000 lbs and the bigger sidewinders rated at 9,000 to 10,000 lbs. Mine is not the mini.
Viperwolf1
electron whisperer
No. There is an oil fill plug on top and I have checked it there before. My winch has never been off since it was installed. I know this because it's actually welded to the frame.
.94 OR
Neighbor had one of those. Worked ok, but having the drum down in the weeds caused friction issues over time. I would make sure to be able to flush out the drum area with a garden hose on a regular basis.
76_fordbronco
76_fordbronco
Well after a year plus of my new (to me) winch sitting in a storage locker in San Diego, I get to pick it up next weekend. I hope to enjoy a couple of meals of great Mexican food while I'm there too.
Desert Rider
Albuquerque
Have the Manual
I have the winch on my 76 Sport. I also have the manual, which I think has some drawings and specs. PM me and I will send you a copy. Good Luck
miikee73
Shadetree Guru
Aloha
I picked one up a while back,it was on a bronco and came with a push bar/headlight surround thing.looks to be a decent built thing ,just don't know how it will look until it's on.Right now it's in pieces and kind of on the back burner.The mounting plate looks to be model specific...and heavy.
