Hi,
This brake has been sold. Thanks James!
I received a High Angle Driveline brake setup when I purchased some other drive train components. I thought I would end up using it; but, I don't see the need at the moment.
The setup is new. It has never been installed.
This is the setup that High Angle manufactured specifically for the Early Broncos.
The brake requires that the Dana 20 be fitted with an HD rear output shaft. This is not included with the brake. The brake also requires an emergency brake cable. (I believe that the stock cable will work; but, I would need to research it more.)
I'd be happy to answer any questions.
Jeff
Jeff
