68 Broncoholic
I'm thinking of adding some high steer arms to the top of my king pins.
Looks easy enough to do myself with 1" thick steel. Anyone else done this?
Since I don't have the axle under the Bronco yet I wonder what the drag link will look like. Probably near level with a stock flat pitman arm. Do you think the uptravel on the pass side will cause a bind at the pitman arm/draglink?
I've seen some mount on top of the pitman arm instead of below in these situations. I can see another bind problem with that when the pass tire drops and the drag link is at full drop.
