They're out there, including some pretty hooty-zooty fancy ones that look uber-cool and pretty well made. Not always easy to tell about longevity by looks though.
I've seen them typically up to about a max of 200 to 250 in our traditional cases that might be considered an easy bolt-on for your 302 lowbush. Some companies, like Premier Power Welder (since you mentioned welding) cap off at about 195 or so if I remember. Above that all the ones I've seen seem to be in the "side-mount" design like would be on an Explorer 4G model, or modern diesel accessory drive configuration. In other words, serpentine only, and you'd have to so some pretty fancy fabrication to make a mount for your engine. Unless you go to an Explorer front dress, in which case you'd be in business. But like was already mentioned, pretty much anything above 100 should be given the upgraded drive method anyway. Even dual V-belts, while a decent improvement over a single, are not enough sometimes. I had to go to duals on my measly 70 amp unit to keep it from squealing. I'm guessing it'd have to be a pretty bitchin' V-belt to work 300 amps up to it's potential.
Someone like highamp.com probably has something in that range. They might even have a standard mount from some import design that could more easily be adapted without changing your entire accessory drive orientation. But you'd still need to change it all to a serp belt style anyway, so maybe an entire front drive upgrade is in order at the same time even for one of the "easier to bolt on" style of alternator cases?
Probably...
You'll likely want a throttle control for welding anyway, but it would also come in handy anytime you have a high load from that alternator trying to bog down the engine. If you're fuel-injected with automatic idle control, you're ahead of the game in that regard.
Good luck. Could be cool, interesting and expensive. But we want to see it when you get it done!!!
